not untill the underground and skm lines are included.jurgis pisze:Ah yes, I haven't actually seen that one working. It would be interesting to compare though, when it is up. Maybe ours will still be betterŁukasz pisze: Oh, okI thougt it is compared to the ZTM's search engine (which is disabled now, because of out-of-date data, but it'll be enabled soon
Rozkład jazdy i wyszukiwanie trasy na trafi.net/warsaw
- MeWa
- Cukiereczek
Actually the timetables for SKM in the pdf are better, because they have each run of a vehicle, not just times in each stop. We'll look for a way to import it.
The metro is a bit problematic, because it has only approximate schedule. But maybe, since it runs often enough, the exact time is not so important, as long as there is some extra time left for waiting during route search.
Rozkład Jazdy: trafi.net/warsaw/
On wap.ztm.waw.pl you can only check ground lines timetablesTeokryt pisze:jurgis,
use wap.ztm.waw.pl to download SKM (and Underground) timetables.
Timetables of SKM can be found on ZTM page:
http://www.ztm.waw.pl/baza/SKM/20080401/LINIE.HTM
(second link shows timetable for this (26-27.07) weekend; there will be another weekend changes at 2-3.08)
Frequency of underground can be found here:
http://www.metro.waw.pl/page.php?id=17
And here you can find times of riding between stations:
http://www.ztm.waw.pl/metro.php
- Solaris U10
Well, the summer is over, and it's time to get back to work even more actively!
On that occasion I would like to announce that the MAP on trafi.net is already working! You can see how the lines look on the map (it is shown whenever you select one), the search result is displayed, and you can also see the locations of all stops.
The information is not 100% complete yet, so some stops are missing (especially for S2 and Metro), and also there is no information about how the lines look between the stops, so they are displayed as straight lines, but the overall look is still pretty nice
P.S. Thanks for the explanation about PKP stops - made some fixes accordingly! About the S2 color - if it is green, what color should the night buses be then?
Ah, got mixed up - night buses are already dark blue, but the suburban buses are dark green. As I understood, S2 is usually also green, so is it the same green as suburban?Fikander pisze:Night buses should be dark blue.
